Ignition only table?
andy198712
Re: Ignition only table?
Post by andy198712 »
Piledriver wrote:A set of low rolling resistance tires may be in your future, and they DO make them in narrow 15" sizes.
If faced with only putting 2 on, put them on the front (if same or narrower than rears) as driven wheels allegedly have ~no rolling resistance.
(Or at least that was AUDIs theory at one point, came up when they developed the UrQuattros, and they still went JUST as fast as 2WD despite the increased drivetrain losses)
I have just about gotten back to ~35 MPG (US) with my setup (went from MS2>MS3+changing WB setups) and the next step is going to be a 914 5 speed or LRR tires. or both, when the tires are in need of replacement.
Tire pressures and wheel alignment really start to be critical once you are trying for >35 MPG.
14point7.com has a new $99(OK, $105 this week) sealed analog-only flying lead WB system that just came out.
...including sensor.
i think your right but i'll have to wait untill after these are cracked ect to swap them.
interesting on the front only idea, i guess it make sense, you having to shove the fronts i guess!
will look into those widebands thanks :)
andy198712
38.5mpg....
think i might try increase the advacne about 2 more degrees on the cruise, see if i can ween out that extra 1.5mpg!
andy198712
41.57mpg!!! New personal best and I have no ideas how!! :)
It's all in the ... throttle foot.
I go between 25-32 MPG for no apparent reason, seems to be traffic related, mostly.
andy198712
Piledriver wrote:It's all in the ... throttle foot.
i agree mate, traffic, road speed, weather maybe... how heavy my foot in.... i rarely floor it now, goes almost as fast if i dont really.... seemingly! i also put my foot down slower so the pump doesnt squirt so much fuel
andy198712
well i've filled up lots of times since and my average is 39.08MPG caries by 1MPG max really...... :)
might fiddle the map a little more today, increase the cruise advance a couple more degrees maybe, see if it likes it!
andy198712
just adjusted to this map and seems purkier every so slightly, just increased the cruise advance really and the idle by 1
got 35mpg last fill up thus the tweek of the map but was mostly do to my lazy driving and not trying lol
supaninja
Post by supaninja »
Andy-I just took a trip down memory lane and read the first page of this thread, back in July you were a complete newb to ignition tuning. Fast forward it to today, you have a complete understanding and the ability to feel what the motor wants. That is a very powerful skill to have, I can't wait to see what you do with the big motor. Tuning ignition is the tricky one, tuning fuel is literally a walk in the park is you have a wideband.
viewtopic.php?f=14&t=140387
andy198712
supaninja wrote:Andy-I just took a trip down memory lane and read the first page of this thread, back in July you were a complete newb to ignition tuning. Fast forward it to today, you have a complete understanding and the ability to feel what the motor wants. That is a very powerful skill to have, I can't wait to see what you do with the big motor. Tuning ignition is the tricky one, tuning fuel is literally a walk in the park is you have a wideband.
Yeah tell me about it! took me ages to get my head around it all the first time but now i look back and thing how easy it would be to do again!
maps changed a bit too
thanks for your help bud!
true what you say about seeing how it feels EG that bit around 75-85 and 1000-1500rp, where its advanced more, thats due to me living on a hill and when i pull away and crawl up it in first its right there on the map and it needed a little more in that one patch to pull smooth especially when cold.... i really only use that area for that situation, but you wouldnt get that if i had of just got it dyno tuned....
fun journey! hopefuly the transition to EFI is a smooth one huh!
andy198712
33mpg....what :?
supaninja
Post by supaninja »
It might be a winter blend of fuel, my daily is getting 4-5 mpg less right now too :(
Jadewombat
Post by Jadewombat »
Aren't imperial (UK) gallons a different size than US gallons?
andy198712
supaninja wrote:It might be a winter blend of fuel, my daily is getting 4-5 mpg less right now too :(
that makes sense..... and maybe my lazy driving going a bit quicker, just re adjusted the brakes but none were binding, will check the tyre psi tomorrow...
also i dont think my engine is warming up very well so installed a stat, will see how it goes! i was getting mayo in my cap and i do regular 30 min runs(50-60mph) so should be getting hot
andy198712
Jadewombat wrote:Aren't imperial (UK) gallons a different size than US gallons?
yeah... ummm
imperial gallon is 4.54 litres
US gallon 3.78 litres
so wicky says
andy198712
currently playing with a cheapy no tech water injection setup (vacuum) but sadly about to start navy training so results will have to wait!
