I'm working on the next batch now since the demand is still really high.
If anyone else wants to get in on round two you can go here - http://thedubshop.goodsie.com/mini-cam-sync
Yes, I still plan on doing those.luftvagon wrote:Are you also planning Mini+Cam+Crank Sync?
Thanks Pile, I can weld it up to verify that. I have 2 to work with. What other brands can read a 36-2 though? I need them as universal as possible with the least amount of partsPiledriver wrote:I can probably weld that up for you as needed, at least so you could validate it works/not.
(hell, I can even test it)
The above would be 7k at the crankFiatdude wrote:Electromotive was always saying the smaller the wheel the less rpm you can run -- something like a max 7K on a 5" wheel -- have you tried spinning that up around 7-8K and looked at the signal???
Could you use a shape like that on the end of an IRS drive axle? I've made these shafts before, but don't know if the depth of the grooves is deep enough to work. Also, you might consider having a shaft hobbed for a gear at a gear manufacturer, then have your local machine shop cut them off into disks. I believe it would be cheaper than EDM.MarioVelotta wrote:They are a couple months away. But I am taking pre orders. The machine shop has a 6 week lead time as of now and I need a coupe weeks to get them assembles and tested.
I really wanted to get the new ones into production but everyone has kept me too busy. A good and bad problem to have at the same time
Here is a 24-1 I had wire EMD cut. This is super tiny and super precise and also expensive.
Here is the scope shot, to bad it doesn't pick up the 1st tooth so well. So the 12-1 will have to do, I can get an 18-1 though that would probably work great but I think that would limit some ECU's options.
Anyway, I am taking Pre-orders for the next run of Cam Sync's. If anyone is interested and want to secure one, just drop me a PM
