A bit of progress whilst the body gets finished off and we are confined to the house (read: busy work)....
Chargecooler water jacket(?) and AN-12 fittings welded on by Steve (thanks, you're awesome!)
Despite this being an OEM Audi intercooler the Aluminium was full of impurities and didn't weld nicely.
Plonked it in a bucket of water with one AN-12 blocked and the other with a PCL fitting, stuck in 15psi from my compressor and two things happened;
1. A small stream of bubbles came out in one spot that looked like a minute pin spot in the weld (impurity?)
2. It bulged a bit......note to self, 15psi is a bit high for this water cooling jacket leak test.
Back to Steve for a quick zap here
Picture is weird, it was stood on an Orange bag when I took it lol
Tested again, no leaks and I pushed the bulges down.
When I can get to do the engine mock up I can figure out the pressure / end caps and tube layout in & out.
I had mirror polished the fan and shroud, coated them in WD40 and left them in my garage over winter. Now they look like crap in comparison. I hate polishing so plan B.
I drilled out the aluminium rivets and sent the steel parts for Zinc with Black chromate conversion (being done as we speak), threw in the glass lifter channels for the hell of it
I'm going to Satin Black powder coat the fan and shroud, so had to take 0.4mm off the radius here to allow for paint thickness (thanks again Steve!)
Not sure when I'll be able to visit the powder coater unfortunately.
