250HP+ 1600DP Mouse Motor
madmike
Re: 250HP+ 1600DP Mouse Motor
Post by madmike »
Funny $hit ,There :lol:
John S.
Post by John S. »
That’s nuts!
MarioVelotta
Post by MarioVelotta »
Got the engine running NA for break in. Pulling the oberg filter apart tomorrow to check out how it looks.
Sounding good though πŸ˜ƒ
The Dub Shop
Mario@thedubshop.net
1600 ITB NA - 18sec
Facebook-Tech-Store
buguy
Post by buguy »
Sounds good! Do you have a target boost number in mind for it?
Clonebug
Post by Clonebug »
buguy wrote: ↑Wed Apr 15, 2020 2:45 am Sounds good! Do you have a target boost number in mind for it?
His goal is 250 hp and up to 300 hp............
MarioVelotta
Clonebug wrote: ↑Wed Apr 15, 2020 5:25 am
Clone nailed it. It will depend on the boost I can make and if the combo will still be making power at 7000+ or falling off. If I don't see at least 250rwhp my life is over...
The Dub Shop
1600 ITB NA - 18sec
Facebook-Tech-Store
Clonebug
Post by Clonebug »
MarioVelotta wrote: ↑Wed Apr 15, 2020 7:35 am
90* IAT's at 7000 rpm and 20.0 lbs. boost will get you to 290 FWhp which should be 250 whp at 15% loss. Should be a piece of cake for you.
I really need to rev the crap out of my engine.....this 5500 rpm is killing me. :roll: :cry: :cry:
buguy
Post by buguy »
When your not used to revving your engine it's super scary. Sounds like it's gonna blow! When I was revving mine to 6000 the other day it was terrible! Even though I have a rev limited set at 6200 it's still scary!
andy198712
Post by andy198712 »
stock engines don't like to rev i found, my 2110 really wanted to and just flew up the revs like it was meant to. my old 1200 wasn't so keen lol
panel
Post by panel »
Sounds like the 'accel enrich' is dialed right in ! Revs so nice !
MarioVelotta
panel wrote: ↑Wed Apr 15, 2020 7:29 pm Sounds like the 'accel enrich' is dialed right in ! Revs so nice !
I've spent very little time with tuning. I took the whole fuel table down about 40% from the generated table once it was running then I turned the TPSdot down to 40 from 200 so it was active. I did didn't some time to sync the TBs. That took the longest πŸ˜†That's about it. I haven't put a timing light on it yet so it probably has a little extra advance right now too.
It could also be that it's about 9:1 static πŸ‘
The Dub Shop
1600 ITB NA - 18sec
Facebook-Tech-Store
Kalle
Post by Kalle »
8000+ rpms shoud be possible and your butt dyno will tell you when you should shift. I have never experienced a discrepansie between my butt and the actual curves from the dyno.
I found this old picture of the fuel system and the water/ice tank in my 67. It is a cool effect when you put dry ice in the water but the tech inspections usually do not agree. And a GREAT beer cooler too!
-K-
bug66
Post by bug66 »
I heard a rumour lately regarding IATs.. For every degree over 21C, you loose 1hp :)
So keep those IATs down. I welded 2 700hp cores together for my engine now :)
Boost was created only to make people smile, and make power! 8)
10.626 @ 132mph SCC2016
10.407 @ 134mph SCC2017
10.221 @ 135mph SCC2018
buguy
Post by buguy »
Dang. Looks like I really need to step up my game!
Kalle
Post by Kalle »
bug66 wrote: ↑Thu Apr 16, 2020 1:49 am I heard a rumour lately regarding IATs.. For every degree over 21C, you loose 1hp :)
Exactly why you should ditch the heavy intercooler poop and replace it all with a tiny sized jet of nitrous :D
-K-
