Type 4 eberspacher exhaust in STAINLESS STEEL - needs finishing as its just tack-welded together at the moment.
Was paterned on the original which we were going to replace some years ago (before the Type 4 was wrote off in an accident)
http://cgi.ebay.co.uk/VW-Volkswagen-Typ ... dZViewItem
Item is in the UK but can ship Global.
(Would probably de-tack the welds and ship in a box as this would be easier - I'll mark up the section for re-welding purposes)
STAINLESS STEEL EBERSPACHER EXAUST UP FOR GRABS
HairyYeti
albert
stanlesteel eberpasher
make attetion if you buy that , this pipe is for the front gaz heather in option for différent contry example ,,,canada or the very cold contry , for to make sure , look on samba he have sellers for the gaz heather exhaust pipe ,,, they d,t have same twist , ask at heather man on samba ,,, alb.
HairyYeti
The pipe is for the Eberspacher gas heater that fits over the gearbox - the flat \ pancake shaped one.
Is it a BA4 model..? I forget.
I was there when we (my brother and I) cut, shaped & tack welded this heater exhaust together. We copied it exact from the exhaust that came from the vehicle (it was badly corroded and leaking).
And yes, we did offer it up to the vehicle, and yes, it did fit (our vehicle - a 'stationwagen' model, as the Americans would say - an 'estate' car here in the UK.)
I'm not enough of an expert on Eberspacher exhausts to cast aspertions on this guys comments. It's sold as is, based on the information I have furnished as above and in the item description.
albert
stanless steell
ops, sorry ,for my bad vision ,,,on the picture (e bay) he has the same look for the gaz heather exhaust for the front heather ,, in option ,, for the cold contry ,,,alb.
- Wally
It looks good and as I have had my quite rusty pipe just removed (and it looks indeed exactly thesame), I have made a bid on it
Best regards,
Walter
Best regards,
Walter
