411-412 floor pan
albert
411-412 floor pan
Post by albert »
hey , fans ,do you want original floor pan for the 411-412 ,,, home made,, buy old rear bench frame for the 411-412 and reemoove the carpet and you see the steel frame , and he have the same patern (floor curve ) on the rear back seat ,, you can cut this steell with weell disk cutter and resolder a patch on your rust 412 floor pan ,, same look of original ,,,alb.
wildthings
Post by wildthings »
Good idea Albert, thanks
vwbill
Post by vwbill »
Hey, question about floor pan/ unibody flex? How much flex will the body have at the door opening? Is there enough flex to make the door move in the opening? Is it less or more in the 2dr and 4dr and wagen? Bill
There is not much fles in normal driving...but there is a little. Where you cansee heavy flex is when you jack teh vehicle up. The closed and latched door is a structural part. Ray
