blow Vs Pull through pros and cons
- seabeebuggy
I have seen here people talk about both set up. it seams to me the pull through is easy-er to set up. as there is no need for a enrichment system like a blow through. but it seams to my a blow through will make more power. as you can cool the air. both can have water injection. but it seams blow through is the way to go for the most power. yes ? no?
www.BigMikesGuns.com oe https://www.BMGAA.com
Thomas Jefferson said It may be necessary for a country to have a revolution every 200 years to right the wrongs of a Government.
Got Lead?
Got Lead?
- MinamiKotaro
- seabeebuggy
I was asking in general , what people think about the 2 set ups . not about mine. I just dumped 800$ into a mallory set up. It will be there for a while..
I was just trying to get some people talking here.
Got Lead?
Got Lead?
- fl_buggy
All else being equal, a blow-thru will make more power because any restriction before the turbo really jacks up the pressure ratio of the compressor. Obviously the carb before the turbo is a sizable restriction.
But I feel draw thru is easier to tune because the carburetor acts as normal. Setting aside the setup of a carb for blow thru, its different to tune than a carb that only sees atmospheric pressure.
Draw thru is also a bit cheaper and easier to setup the fuel supply. You don't need a rising rate regulator or higher pressure pump for draw thru. These are pretty minor things but can add up to a generally easier setup.
madpballer
well all th fastest bugs i have seen have been a draw through carb system, or a blow through fuel injection. ive never seen a ms go faster then 12.5 or never heard of one. i know many people have fuelleakage problems on blow through system anything past 15 lbs even when prepped corectly. i beilieve that a draw through system would be better for making power at the track. but a draw thoguh might be a lil more driveable. mostly its breference i guess
- seabeebuggy
How does a draw through go to higher boost levels when you cant cool the air? or can you? keeping it all carb set ups no EFI. I can see EFI making more power . If you cant charge cool then to get higher boost levels in a draw through you must use water injection and or ??? I like the look of blow through but it would have been much better i think to go draw through. but for street use , can you get higher boost levels out of it on super unleaded? or go to race gas? see my point. I don't know if it is a correct point.
Got Lead?
Got Lead?
madpballer
- seabeebuggy
I was all over there wasn't I.
I have both water and a intercooler on my buggy. electric fan to keep the cooler cool. It is a small cooler . I would be shocked if I lost boost. it is about filling volume. maybe it will just take a second longer to get to same boost levels.
Got Lead?
Got Lead?
madpballer
- seabeebuggy
I am sure there are some affects . on the big coolers more so. I would just have to turn the boost up I guess. I don't know how high it will go yet. i hit 17lbs once and i let off the gas when it happened. i run at 12 lbs. but 15 sounds good. I hope to make it on pump gas. with the water/ methanol mix and cooler.
Got Lead?
Got Lead?
- Marty
poop de oiad
Theoretically, with the same boost level, an draw through setup will make more power than a non-intercooled carbed blow through(and possibly fi) due to the cooling effect of the mixture. Not much cooling, but it's definatly there. How does a draw-through run high boost levels w/o cooling? Race petrol.
I have heard opposing arguements over whether or not one loses some boost with an intercooler. I do'nt know about that, but there will be more lag after shifting(especially with a blow off valve). Honestly, I think air-air intercoolers are'nt the best idea for an acvw anyway. Look at how big aftermarket ic's get for porsche 930's and the air-water setups still blow them away. For a blow through, air-water is the way to go.
Add to draw through cons: cold starting and the necessity to keep on tapping the throttle while idling to clear the puddled petrol before the compressor. It's all up to you to decide. Me personally, I like the old fashioned low compression 4bbl d-t approach. I'll take the quintessential on/off turbo feeling to the tiny turbo, "feels like a big n/a", feeling anyday. Maybe not ideal, but it was enough to suprise that s2000 from a highway roll last night!
- seabeebuggy
I have a coolmist set up.
I was just talking in general street driving max power. it would have to be able to be driven.
Got Lead?
Got Lead?
- seabeebuggy
I was thinking of regular petrol fuel not race gas, you can add what ever aftermarket stuff you like. both carb set ups.poop de oiad wrote:Theoretically, with the same boost level, an draw through setup will make more power than a non-intercooled carbed blow through(and possibly fi) due to the cooling effect of the mixture. Not much cooling, but it's definatly there. How does a draw-through run high boost levels w/o cooling? Race petrol.
the only reason I ask this is i see people say draw through is the better set up for power . I was thinking you can get more power with a blow through due to the extra cooling you can add to it. both can use all other things like water injection race fuel etc.
Got Lead?
Got Lead?
