Hello!
Is anyone can help me to locate a good working original 411 fuel pump?
Some people suggested me to use electric fuel pump but I like to the mechanical fuel pump instead electric one.
I have checked the fuel hose has fuel coming thru to fuel pump and no fuel to carbs so it won't start. I also tested with putting fuel into carbs is fired up alright until its run out of fuel from the carbs.
Cheers,
VW411L
411 Fuel pump not working.
VW411L
wasn't fuel pump.
Wasn't fuel pump problem. Is the battery too weak and bought a heavy duty battery. Solved the problem.
