Buggy from Denmark
Niels-Erik
Buggy from Denmark
Iam new here, and my english is bad- but i have made a byggy mrk 3!
Do you like it?
http://vwnettet.dk/pictures/4/5/754/DSC ... 1149551632
Niels Erik
Do you like it?
Niels Erik
Niels-Erik
Niels-Erik
Niels-Erik
I use polystyren foam, glued in place with polyueratahn foam, from a spray can ( i cant spell these words), Then i sanded everything, and cowered the foam with plastic packaketape.
I use polyester, it cant go trough the tape, and after it hardned, it is easy to remove the foam and tape, from the fiber.
I hope that i make some sense- sorry for my english.
Iam as you now from denmark!!
Niels Erik
Niels Erik
Dominicv
Niels-Erik,
That is VERY smart, I never would have thought of that.
Let me see if I understand this right, you applied fiberglass cloth with polyester resin over brown packaging tape, and once the fiberglass cured you were able to seperate it from the tape.
What kind of tape, or what is it made of, regular cellulose?
Dom
Dom
Niels-Erik
The brown packaging tape, is a normal type- the sort all companies use, somtimes it comes in different collors with company add on. it is a plastic tape, i dont now hwat it is made off, but once the fiberglass cured is is verry easy to seperate.
You can make a test - put some packaging tape on a polistyren pice-then lay a few layer of fiber with polyester , and led it cure.
If you use the right tape, the polystyren will not melt, and it is easy to seperate after the hole is cured. And best off all- it is cheap and easy to work with polystyren and packaging tape.
Niels Erik
Niels Erik
Niels-Erik
I used the metod on other things before, and nothing has ever melted.So you go ahad, and make your trike-And lay some photos of the jop!Dominicv wrote:The tape didn't melt, that is wild, I must remember that.
That was very smart of you to think about that.
Maybe I can add some body work to my trike.
Dom
Niels Erik
