Ring & Pinion shims
Bruce2
Ring & Pinion shims
In talking to VW transaxle builders that see far more volume than I do, they have noted that in most cases the thickness of the pinion bearing shim is almost always the same.
For example, an old German mechanic trained by VW of Germany in the 50s told me that a G type 3.88 usually has a 0.6mm shim. The last 3.88 G type gearbox I opened up had a 0.6mm shim, just like he said.
In this topic, I'd like to hear from those that have made observations on what shim thickness is usually with what R&P with a LATE pinion bearing. (We can do the early bearing later)
G 4.37
K 4.37
O 4.37
G 4.12
K 4.12
O 4.12 0.55mm
G 3.88 0.6mm
K 3.88
G 4.37
K 4.37
O 4.37
G 4.12
K 4.12
O 4.12 0.55mm
G 3.88 0.6mm
K 3.88
Hotbugsy
I have run .035 shim in my Rhino cased gear box for Years . I run the car with my turbo set up and have never had a failure... When the ring gear gets noisy, I swap it out for another and re-use the same shim . I know a few people out there that once they find the shim that is most happy in there , thats what they stay with . My spare box will also has the same shim . This don't mean I'm correct, but when you find somthing that works , why change it ?
Bruce2
Re: Ring & Pinion shims
Update from Mike at Rancho.
Bruce2 wrote: G 4.37
K 4.37
O 4.37
G 4.12 0.6mm - 0.625mm
K 4.12
O 4.12 0.55mm
G 3.88 0.6mm
K 3.88
Hotbugsy
My spare Trans had to come apart due to breaking the case in half all the way around ! I used a .018 Shim on my late style big nut set up . Wear pattern looked great ! No broken Teeth from the explosion either ! If I ever use the late style big nut setup again, I will use the same set up with that size shim .
Bruce2
Bruce2
Thanks for the input DD. However, I intended this topic as a collection of shims for late pinion bearings, not early. The same R&P will use a different thickness of shim with each bearing.
K 4.62 .50mm
G 4.37 .6mm
K 4.37
O 4.37
G 4.12 .6mm - .625mm (from Mike @ Rancho), .55, .70, .55, .60, .60
K 4.12
O 4.12 .55mm
G 3.88 .6mm, .6mm, .65mm, .65mm
K 3.88
O 3.88
- Lo cash lester
Just pulled a K-3.88 apart and found .1mm shim. This was, as far as I can tell, a factory build. Had been setting for a very long time and everything looked premo inside. Ended up using the same shim in another case for a swing axle car. Lester
K 4.62 .50mm
G 4.37 .6mm
K 4.37
O 4.37
K 4.12
O 4.12 .55mm
K 3.88 .1mm
O 3.88
