Buggy Turbo 2,1 DJ *Bugun 09*
Rydh
Post by Rydh »
I have a buggy whith a 2,1dj engine and the plan is to turbocharge it whitout changeing the pistons, i know that the best thing is to install MV pistons instead but i don't want to take the engine apart and i am glad to get just 20-30 extra ponys out of it.
The plan i to install a Mitsu Tdo4-13c from a volvo and a nissan 200sx intercooler and new injektors/fuelpressureregulator (perhaps progressive). For starters run on 99octane shell V-power and then try E85 (15%gas and 85% ethanol) both is easily available in any gasstation here in sweden.
Has anyone tryed this before on a stock DJ engine? any other thougths?
Pic of the car:
More pics: (in swedish)
http://www.vwtyp1.com/forum/viewtopic.p ... rydh+buggy
//Rydh
marcotheturbosteamengine
Post by marcotheturbosteamengine »
you will be fine, but only if you run it in E85, you will be amazed at how much you can boost a DJ 2.1 on E85, oh and a good F,I EMS is a must.
good luck
marco mansi.......
Rydh
Post by Rydh »
marcotheturbosteamengine wrote:you will be fine, but only if you run it in E85, you will be amazed at how much you can boost a DJ 2.1 on E85, oh and a good F,I EMS is a must.
good luck
marco mansi.......
Thanks, the only thing that remains now is to start building! :wink:
//Rydh
fastback
Post by fastback »
Th DJ has 10,5;1 i comp. so you should get control of your ignition so you can retard it a bit under boost.
I run Megajolt/EDIS . on my WBX .
Cheap and nice working!
Rydh
Post by Rydh »
The build is now on it's way!
//Rydh
51MAN
Post by 51MAN »
Cool....
:shock: :lol:
Rydh
Post by Rydh »
Moore pics!
//Rydh
Rydh
Post by Rydh »
More uppdates:
I´m now running it on 5psi boost and stock ignition and larger injektors and an ajustable fuelpressureregulator and it works great. (98octane)
I started it this weekend so there is a bit more adjusting to do, and I´m going to try a bit more boost.
Some pics:
Some movies:
http://www.brumm-brumm.se/filmer.htm
//Rydh
akciddento
Post by akciddento »
all the movie links except one say 'incorrect volume or directory' when i try and play them, just thought i'd let you know
Rydh
Post by Rydh »
akciddento wrote:all the movie links except one say 'incorrect volume or directory' when i try and play them, just thought i'd let you know
That's strange, They seem to work fine here..
Yesterday i did a bit more adjusting of the FI
Now i run 3,2bars fuelpressure and 5 steps more tension on the spring in the afm and 5psi of boost. I'm using 214cc volvo (borsch) 0280 150 762 injectors
No nocks, just a little bit rich on full boost and Just a bit on the lean side on partial load but as son as i open the trottle a little bit the AF meter ligths up, Perfekt 8)
Next step is more boost!
//Rydh
akciddento
the buildup pictures and blog are great ! keep up the good work!
inspires me to get stuff in gear and on the track :)
dan
tencentlife
Post by tencentlife »
That's sweet. Think I could shoe-horn one like that into the back of my Vanagon?
How are you cooling the radiator/intercooler? Does an electric fan have to run all the time, or is there some ram-air ducting? I couldn't see how you did it in your pics.
Rydh
Post by Rydh »
tencentlife wrote:That's sweet. Think I could shoe-horn one like that into the back of my Vanagon?
Thanks, Nothing is impossible, but perhaps not with my kind of manifold!
The fan runs over a thermostat and over the radiator and intercooler i have a Scoop, the one on the pictures i temporary, the new one is on its way:
//Rydh[/quote]
Rydh
Post by Rydh »
fastback wrote:Th DJ has 10,5;1 i comp. so you should get control of your ignition so you can retard it a bit under boost.
Sorry, i didn´t read this until now :oops:
The vacumadvance"bell" seems to bee working with boost aswell. If I put 0,8bars of kompressed air in the inlet it will retard the ignition 7-8degrees based on my messurements. So at 0,3bars of boost i will ha a retard of about 3-4degrees, i think that it will work fine.
//Rydh
fastback
Post by fastback »
nice.!
Since u have swapped tje injectors to bigger ones, did u adjust the AirFlowMeter or replaced it with a bigger one to compensate for the extra fuel?
