new zurst
plumcrazee
new zurst
Post by plumcrazee »
just had my stainles zurst mad for the 412 looks wicked and goes so much better
:wink:
just got to put the rear valance back on and wash the car lol :lol:
So you made it....or had it made...or someone sells them? Thats cool! Tell us about the inside plumbing path...and sizing/volume. I have numerous designs of improved stock exhaust I have been swirling around in my head for a while. Ray
plumcrazee
hi ray i have had it made by turbo tomas over here in the uk
its a 6" cylinder with race exhaust internal packing so it quierter than the stock pipe untill you open it up. with 40mm twin pipes from the heat exchangers to the zurst box with 60mm twin outlets. i am keeping the stock heat exchangers for some heat in the loverly british weather lol :wink:
its a shame he droped it when fitting as the dents wount come out now :cry:
still got it cheaper lol :lol:
Wally
Post by Wally »
Than you must have dropped the rear bumper too huh? :lol:
Lovely design and looks well indeed.
I want something done about that too and am looking to have a heater box made with a little larger diameter and then bolt the 4 into 1 BAS header to it which has a larger diameter as well. That will take some time tho...
plumcrazee
Wally wrote:Than you must have dropped the rear bumper too huh? :lol:
:oops: :oops: :oops: :oops:
yep i had an argument with a concrete balard it it won :roll: :wink:
Yes, its interesting ....in that the stock exhaust set-up was a marvel of pacage design. Its only real drawback was that it needed a few internal plumbing changes (easier said than done in that small of a space)...to make it less restrictive.....and short of the 1.7L...it needed more internal volume.
A prime example of just what volume changes can do with teh stock exhaust design...is in the Ernst variant of the stock muffler. It had roughly 15% greater internal volume, maybe 10mm larger center exit collector with perforations roughly 20% larger. It was a noticable change over just the OEM...in both radiated heat and back pressure.
As for plumbing changes, the stock muffler is essentially a 2 into 2. The 3/4 side is paired into the same pipe and the 1/2 side is into the same pipe.
The inequalities are this......the 3/4 cylinders are ducted to the right hand end of the main chamber (on our versions). They bleed exhaust through perforations in this pipe (on some makes)....on others they just dump into the right hand side of the main chamber....wherin they must make a 180 degree turn to start difusing into the main center exit pipe.
All this time...the 1/2 side goes all the way to the left end of the box...to make a 180 turn....but do this right at theend opening of the center exit pipe so the 1/2 cylinders have a shorter path to exit and less resistance.
If you could keep the 3/4 pipes seperate....the whole length of the chamber...so they made their 180 turn and then dumped straight into a center exit pipe...and have the 1/2 pipes do the same in the opposiute direction....you could then have equal paths....and less turbulence. This would as you see.... require a tail pipe at each end.....like the one you have. Cyls 1 and 2 exit left, 3 and 4 exit right. I would use two center pipes...stacked on top of each other. You would then need a bisector plate through teh center of the muffler. It could be done.
It would not be a power "producer"...like say a tuned header, but at least it may not be a power loss. If you had a stock style free-flowing exhaust that sounded quiet...that would not be a heat banking radiator.....and kept the heads cool....I would buy one. Ray
