Overhead fan wiring
DesertGolfGuy
Overhead fan wiring
Post by DesertGolfGuy »
I just had a brilliant idea (which means uh-oh or oh crap, depending on which woman is closest). I want to put gauges in my '64 single cab. Just so happens I have the metal panel off where the air vents into the top of the cab.
The question is...how is the wire that is there (the fan isn't) routed. I could route the gauge wires to there then cut the metal panel and install the gauges.
I used magnetic bars from home depot on top of the dash to hold the tach and it is working fine.
Thanks.
Post this in the electrical forum someone should be able to come up with a wiring diagram.
