making drop spindles
Damhippie
any one know how to make drop spindles I know you need two sets and know I can do the mod but how
Pillow
You would need a lot of equipment to get them machined properly from what I understand.
Honestly it is probably cheaper to just buy a set from Rizzag than to risk doing it yourself.
http://www.thesamba.com/vw/classifieds/ ... p?id=83911
These are what I run and am very happy with the product.
Tree Hugger
Splitty Spindles?
I've made my own you just need access to a press to press apart then back together, check these links they should help.
http://sinclair.fotopic.net/c854575_1.html
http://forums.lowlifevw.com/viewtopic.p ... ght=#59189
Good luck!
Good luck!
That's a nice hack, excellent work!Tree Hugger wrote:Splitty Spindles?
Good luck!
THEBURG
I got mine from Franklinsvwwerks. I watched him make a set, and beleave me, it's involved! You don't happen to have a 2 ton mill sitting in your garage do you? No...nether do I
, but for a few hundred of your hard earned dollars, you can get a set from Frank. Or check out Red9Design in the UK, Simons got a nice kit he sells.
Good luck!
Good luck!
