Tonneau cover-type thing?
vwthingboy
I was wondering if anyone has ever made a vinyl cover that would be like an old school roadster kind of setup for the back of a Thing.
What I'm envisioning would be for use on a Thing with no rollbar and the entire top mechanism removed.
The cover would attach to the widgets that hold the top to the body in the back and on the sides.
From there it would cover the luggage area and possibly extend over the back seats, somehow attaching to the rear door beading.
So it would be like a truck bed cover, sort of.
vwthingboy
I found some pictures of a Type 3 roadster with a similar thing:
http://www.thesamba.com/vw/forum/album_ ... _id=344067
http://www.thesamba.com/vw/forum/album_ ... _id=344069
- bciesq
I asked the same question about a year ago:
http://www.thesamba.com/vw/forum/viewtopic.php?t=128940
My inspiration was the boot top on a friend's old MGB.
The best advice I got was to go to a shop that specializes in covers for boats since they are used to custom jobs. I haven't looked into any further, however.
vwthingboy
Ben,
It does sound like we're talking about similar things.
As far as the door/side attachments, I think one could have separate door top beading which would have snaps affixed to the outside.
I'm not sure where to find a shop that could do it around NYC.
If I make any headway, I'll let everybody know.
- Kubelmann
- bciesq
I think we all may be talking about two different designs.
The easiest way to design this would be pup tent style. Use the existing rear eyelet clips in the rear and then attach the other end to the top of the windshield. The sides can hang over the doors with a little extra material and be anchored by small "bean bag" pockets or by fiberglass inserts that would hold down the sides. This would easy to raise and lower, and would not require any modification to the car, but I'm concerned that it would stress the windshield over time.
In order to achieve the tonneau cover effect like on the MGB and Type 3 roadster linked above, you would need some method of attaching the cover to the area where the windshield and dash meet. Other than modifying the car for clips a la the MGB, perhaps it would be a simple matter of having enough cover material to slip between the windshield and the body. Just unhook the windshield and pivot it forward, slip the cover in the gap between the windshield and body, then lock the windshield back down. The rubber gaskets on the bottom of the windshield and the body would hold the cover in place. Zip out sections for the driver and front passenger would allow for easy access in 99% of expected uses.
I'm just spitballing here.
Thoughts?
Thoughts?
74 Thing
The Thing Shop made one many years ago. It attached on the rear to the loops just as the regualr convertible top fit and then up front it went underneath the windshield and there was a zipper for the drivers seat. Downn side is if you have a roll bar you cannot use it. They produced it about the same time they had those pick up truck tops.
- bciesq
Wow, sounds like we're on the right path. I'll contact the TS and see if the still have the pattern laying around.74 Thing wrote:The Thing Shop made one many years ago. It attached on the rear to the loops just as the regualr convertible top fit and then up front it went underneath the windshield and there was a zipper for the drivers seat. Downn side is if you have a roll bar you cannot use it. They produced it about the same time they had those pick up truck tops.
- Captain Spalding
