Problems with search
mpdykeman
Post by mpdykeman »
Are others seeing the same problems I am trying to run searches against STF? More often then not I get a blank page back, or some kind of timeout problem. Occasionally Ill go back and search for the same thing and get a full page of hits... Pretty frustrating knowing that there is a wealth of information in here for me but I end up having to go back and ask questions that have been asked a hundred times because I cannot effectivly search the database...
Can Drive Soon
Post by Can Drive Soon »
Yeah, the search function here is sorta iffy here. If you play around with it for awhile you usually get results.
doc
Site Admin
Post by doc »
I hate the search function, but it is what it is as part of the board software. We continue to chase this issue but have no answer to date. Wish it was different. Like CDS suggests, stick with it, you're searching almost a gigabyte of archives.
doc
doc
Site Admin
Post by doc »
BTW, if there are gurus out there who have advice or some proposal that would improve the search capabilities of the board, I and AdminSteve (who is the brains behind the board) would be happy to hear it. I point out, though, that it is a fairly complicated issue. STF is a big database. How you search may make a big difference. Several other seemingly unrelated variables can really distort conclusions. It's a tough problem.
What I can tell you is that we have plenty of server power and resources, so that doesn't seem to be the problem. The search facilty embedded in our board software is pretty weak compared to "cutting edge" search facilities.
So, if you have the magic bullet I'd like to hear about it.
doc
Post by Marc »
In most cases when Search has returned a blank page, I've found that simply refreshing the page often works. If that fails I'll try a slightly different query. Yes it's kinda slow & frustrating sometimes, but rarely have I not been able to find what I'm after.
Simple solution is to ask the moderator for some help, he should be familiar with his forum and can steer you in the right direction.
doc
Site Admin
Post by doc »
Both good options. Thanks, fellas. As well, we will hope that the version 3 software will be more robust.
doc
Can Drive Soon
You could do a site specific google search. Like
Code: Select all
Type 4 site:www.shoptalkforums.com
Type 4 is the search topic and the site:www.shoptalkforums.com is where it searches through.
doc
Site Admin
Post by doc »
Another suggestion that might pay in a pinch. 8)
doc
Can Drive Soon wrote:You could do a site specific google search. Like
Code: Select all
Hey, that's my trick!!! :lol:
You may have posted it first!
(should be general knowledge by now)
