rocking in steering
Barry
rocking in steering
Post by Barry »
I have a 90 Vanagon with power steer
At low speed i get a noticable "rock" to the right and then back
It disappears the faster you go but i wouldnt way it is speed related - as in wheel balance
It is a slow pulse, like i a second?
Any ideas??
wildthings
Post by wildthings »
Just taking a guess but it sounds like you either have a bent wheel or a busted belt. Jack it up and spin it and see if it runs true.
Barry
Post by Barry »
By belt , do you mean power steering??
Cause that is fine.
I will check the wheels but they are mag and i cant see any marks on them - but i will jack it up and look
wildthings
The belts are the plies of the tire that underlie the tread. They help keep the tread flat and if one breaks it will result in a bulge in the tread that causes the symptoms you are seeing. Pretty common to see this when you are running worn passenger tires on these heavy rigs.
Barry
Post by Barry »
wildthings wrote:The belts are the plies of the tire that underlie the tread.
hmmmm.......... now you got me thinking
They are an older set of tyres on the front
Might do a full rotation and see
udidwht
Post by udidwht »
Check your front tires closely, I'd be willing to bet you have a bulge in the tread.
Barry
Post by Barry »
OK - i owe you guys a beer
The front tyre had a bulge on the side of the tread.
Not the side wall - so i couldnt see it
Perfect again
:D
wildthings
Whats the best beer down under? Glad you found your problem before it went critical.
Barry
Post by Barry »
wildthings wrote:Whats the best beer down under?
Anything cold!
