Here is a basic procedure to intitially diagnose the components of a Thing wiper system
Pull the brown and black connector from the wiper motor. Attach a volt meter with the negative lead to the brown wire and positive to the black wire. Turn on the ignition switch Turn the wiper switch to the first click or speed one. The volt meter should read 12 vdc Replace the black wire.
Pull the brown and black and yellow connector from the wiper motor. Attach a volt meter with the negative lead to the brown wire and positive to the black and yellow wire. Turn on the ignition switch Turn the wiper switch to the second click or speed two. The volt meter should read 12 vdc
If either of these tests fail you have a bad wiper switch or a bad power lead or a bad wiring ground. The bottom line is you have a wiper switch problem.
Using an external source of 12 vdc other than your car, attach the negative lead of a 12 vdc source to the wiper motor negative terminal (where the brown wire goe) and positive to the terminal (where the black wire goes. The motor should turn speed one or slow.
Using an external source of 12 vdc other than your car, attach 12 vdc to the wiper motor negative to the terminal where the brown wire goes and positive to the terminal where the black and yellow wire goes. The motor should turn speed two or fast.
