Still need a fuel gauge. Anyone? Anyone?
- SureFit Travis
Well, I've gone done it good! My fuel gauge stopped working, which I replaced when I got the car....and the sending unit is fried too. This was replaced before I bought the car. So now I'm on the hunt for both the sending unit, as well as the gauge. Oh, and a proper wiring diagram.
The car (as some of you know) is a '73 412 2-door, with the twist-lock style sending unit.
Any help is appreciated!
Travis
Travis
Last edited by SureFit Travis on Mon Sep 03, 2007 11:00 pm, edited 1 time in total.
wildthings
- func412
Here´s a link which clarifies my recent statement: http://www.sso-usa.com/marine/Technical ... Sender.pdf
- func412
... and on page 28 you can see the different lengths: http://www.siemensvdo.com/NR/rdonlyres/ ... 007_en.pdf
- SureFit Travis
Thanks for the responses; I think I have located a sending unit for a Super Beetle that will work, and now I just have to locate a gauge. Thanks, func412, for the links, however that style is different than what my car has (twist-lock vs. bolt-in).
I see that GermanSupply.com is selling an NOS dash clock/fuel gauge, but it is not the kind with the vibrator block on the rear, so I'm not confident that it is compatable. My clock works great, so I'm reluctant to buy it.
Anyhow, now my search has been narrowed down to just the gauge......(and correct wiring diagram!)
Travis
Travis
- Wally
AFAIK, it doesn't. Mostly because the arm is on the totally wrong side. The screw-in is indeed the same..SureFit Travis wrote:; I think I have located a sending unit for a Super Beetle that will work,
Travis
I am looking for quite some time for a new one myself as well. I tried to remodel a beetle unit, but that didn't work and the new (brazilian) unit appeared to be broken from the factory too, so I totally gave up on it..
- ubercrap
IIRC, MoFoCo (http://www.mofoco.com/) used to have a box full of NOS ones they were selling individually on ebay, don't know if they sold them all. Worth a shot if you don't mind being laughed at.
- SureFit Travis
- Wally
- SureFit Travis
This is a very old memory...but I beleive (think) either gauge works with either sender. But...the accuracy may be suspect as the calibration might be different on the sender itself.
Bear in mind.....the 411/412 gauge unit (the entire housing)...was also used in the late Ghia. Two years ago...Kerr automotive in Oklahoma city had two brand new complete units in the box...
. They asked me if I wanted first dibs. I have lots of used ones so I said no. They were contemplating E-bay. You could call and ask...405-232-9581. I have a couple of good used 412 late gauges...probably minus the clock. Let me know if you end up in need. I have some early 412 gauges and some dedicated '74 412 gauges (at least one). Ray
- SureFit Travis
Well, with some slight modifications to the notches in the Super Beetle sending unit (had to cut a couple a bit larger), I have it successfully mounted in the tank. Impedance from 10 to 106 ohms.
The gauge was a bit of a different story. I wanted to retain my original clock, so I took just the gauge out, and put the older one in (again, slight mods to the mount of the gauge to make it slide in). Wired it up......and she read full tank.
Now, I knew the tank was only about half-full, so I pulled the sending unit, and tested it at different levels. The gauge worked correctly for a very brief period, then read full again. Put the sender back in, and played with the gauge.....okay, found a short. Fixed the short, but now it still only reads full. Dammit.
Retested the sending unit (this time, while in the tank....read 65 ohms), and checked the wiring to/from sending unit, and they are fine. Even by-passed the wiring thinking it may have rubbed through, and was shorting out....but not so. Sending unit and wiring confirmed okay.
So, yes, I'm still on the hunt for a gauge (just the gauge, not the clock). I have the original gauge, as well as the replacement I put in shortly after buying the car from Jen, and both of them have broken wires inside (very fine wire). If I can't turn up another used one, I will have to do some more research to see if I can adapt one from another VW (Ghia, S. Beetle, Van?).
I REFUSE to GIVE UP!!!
So there.
Travis
So there.
Travis
- SureFit Travis
