I need new wheels
- CapnDavy
I need new wheels
The local bug mechanic announced to my surprise that the THING wheels are different from the Bug's.
Three of my wheels are so bad they cannot be balanced. The car shakes badly in the 50-60 mph range.
I've seen the wheels at the THING SHOP but wondered if there are alternative THING wheels and suppliers.
(Can't find the "search" button on this forum so forgive me if this has been asked numerous times in the past.)
Dave
Dave
- MNAirHead
- CapnDavy
Thanks for the quick response... you're up early out there in the WEST.
I'm not particular about the stock look. Just want to get some new wheels. I'm planning an interstate trip and need to get a smooth ride above 60 mph. Not an 'upgrade", just replacement.
This is an unmodified '73 with drum brakes.
I did see new wheels at the Thing shop in the neighborhood of $180 each. (!)
I hesitate to buy used 'reconditioned' wheels. Who knows if they are straight?
- Towel Rail
I've found the Thing Shop to be a straight-up operation. I haven't purchased wheels from them, but I would be VERY surprised if they are not perfectly usable.
If you're not interested in spending a lot of moolah for 14" Thing wheels, 15" Beetle wheels can be used. They're plentiful and cheap.
Another tip: Buy one of these, and any tire shop in town will be able to check your wheels and balance your tires. WELL worth it! http://www.thesamba.com/vw/classifieds/ ... ?id=373915
- Scott
P.S. Also, beware of 14" Bus wheels. They have the wrong offset.
- Scott
- Towel Rail
Well, you then have to use 15" tires, that's the only downside.
Any aftermarket wheels that fit a Beetle will fit a Thing. As long as the wheels/tires are the same left-to-right, you could run 14's in the back and 15's in the front, or vice-versa, if you chose.
Lots of options -- my Thing is going on 7.0x15 tires (stock Beetle wheels) after my resto is done.
- CapnDavy
MNAirHead wrote:Welcome to STF.
Thing rims are 14" Offset is specific to rims.
Are you looking for stock or some type of "upgrade"
Let us know -- we'll help you source the parts.
I did see new wheels at the Thing shop in the neighborhood of $180 each(!)
People are telling me I can use any VW 15" rims but they don't discuss the offset. What is that and how much is it?? (how is it measured for the THING?)
- Towel Rail
Chris V
Thing wheels are 14x5 ET 32.5mm
Beetle wheels October 1952 through July 1965 are 15x4 ET40...after that they were the same dimensions, but with ventilation slots.
Bus wheels December 1963 through July 1970 are 14x5 ET47.5mm
You can correct offset with "pass through" spacers:
http://www2.cip1.com/ProductDetails.asp ... C10%2D6704
http://www2.cip1.com/ProductDetails.asp ... C21%2D2527
http://www.joesracing.com/
Son of Marc
Son of Marc
- Captain Spalding
Okay, that 32.5mm is offset, right? Equal to 1.28"Chris V wrote:Thing wheels are 14x5 ET 32.5mm
Proceeding under the following premise:
Offset = Backspace - (Rim Width ÷ 2), therefore
Backspace = Offset + (Rim Width ÷ 2)
Backspace = 1.28 + (5 ÷ 2)
Backspace = 3.78
But I have empirically measured the backspace of my stock wheels to be 4 3/8". What am I missing?
- Kubelmann
