CB bigfootlifter in a WBX
fastback
Post by fastback »
Got my hands on a set of these vintagelookingblisterpack of bigfoot lifters.
Pretty heavy , but makes the camchoices a bit more.
any good?
Oil groove could be better..
more info appreciated.
VW type 2 splitbus 2.1 WBX turbo
11.92@187.89Km/h.
Unkl Ian
Post by Unkl Ian »
The old lifters typically were much better than the newer stuff.
Rolf
Post by Rolf »
They are HEAVY, like 141 grams !!!! 5o grams more that a stock lifter. They need strong valve springs to prevent them from bouncing on the cam. I have seen them in a type 4 engine that was used for dragracing and the cam went flat/broke within a few runs. The lifters and cam looked REALLY bad. But for a street engine with moderate cam choise and good strong valve springs the lifters can be used.
Just my 2 cents
/Rolf
fastback
Post by fastback »
i'll test them in WBx that has OK dual springs and maybe a TCS-20 cam..and turbo ofcourse :)
but'ill make the oilgrove a bit bigger.
marcotheturbosteamengine
Post by marcotheturbosteamengine »
you may have to deck the lifterbores 3-4mm because at full lift the extraspace the big foot takes up will go cambind!!!!
fastback
Post by fastback »
yes i noticed :)
148 Grams before removing some material.
i also put a hydraulic lifter ,filled with oil, on the weight: 117Grams
fastback
Post by fastback »
Hey Rolf
Would u mind check if your friend has one or more of these lifters still laying around??.
and if they could be re-used with a regrind?
had an accident machining one of them.. :(
Rolf
Post by Rolf »
Hi Fastback
I will ask around if anybody still have contact with him, he vent out of the VW hobby years ago. I'll be back later.
/Rolf
fastback
Post by fastback »
great
SiQDiZ
Site Admin
Post by SiQDiZ »
mind you that the hydraulic standard lifters in the WBX are filled with oil, so that adds additional weight to the original lifters :D
tencentlife
Post by tencentlife »
True, a few grams. The volume of oil inside the lifter couldn't be more than 3cc, and oil is lighter than water.
fastback
Post by fastback »
fastback wrote: i also put a hydraulic lifter filled with oil, on the weight: 117Grams
yes :)
Rolf
Post by Rolf »
Rolf wrote:Hi Fastback
/Rolf
Fastback,
No luck in finding this guy, sorry !!
Have you asked CB Performance?
They might have some left overs.
Just a thought :wink:
/Rolf
fastback
Post by fastback »
thx for the effort rolf.!
I'll see what i'll come up with... but i have more or less trown away my plans with these anyway..
Rolf
Post by Rolf »
I hsve used some of Udo Becker lifter sleeves for type 1 lifters in a friend's oxyboxer and they works fine. I have made a drift to install them with and when the sleeves was cooled in the freezer and the case was heated a little bit they went in like a hot knife in butter :P
/Rolf
