228 flywheel+wbx pp into 412 tranny
- func412
Has anyone tried this? Is it possible to fit it in?
- func412
- Wally
So you need a custom disk and not many companies can/will do this. I 've asked around over here, but came up empty...func412 wrote: He modified a disk using 412 center and rest of the disc came from Audi.
Its the same problem here as well. Most clutch rebuilding shops are pretty low tech actually. They don't "make " anything. They simply replace parts like linings and ...even rarer....a center hub on a stamped disc.
I have found them very very afraid of de-riveting one hub and riveting on another. In most places they don't d riveting unless they have to. They simply re-blank all of the exiting rivets, check for cracks and straightness and slap on new friction material.
But...bear this in mind, most if not all of the 411/412 discs I have seen on our continent are solid center...not spring. I have never actually seen a spring center 411/412 clutch disc.
And....The 210 and the 215 take the same exact center plate. If you will notice.....the metal plate sandwiched between the friction surfaces on the 215 is recessed in...about 2.5mm....
from the outer perimeter. Its the same disc with larger diameter frictin material riveted on. It worked fine in that configuration.
If you did the same thing for a 228...it would 7.5mm further recessed from the edge. It might be possible to do this.
If not...you best bet if to get a solid 228 disc......grind the rivets off the center hub...and re-rivet the 411/412 hub to the new 228 center hub. At that pint...I would think it would also be safer to spot weld around the hub to the disc. Just some thoughts. Ray
- Wally
I actually have one of those lying right here for the new 2056cc engineraygreenwood wrote: I have never actually seen a spring center 411/412 clutch disc.
Ray
Just mentioning this so you know they exist
- func412
Yes, the flywheel fits in with the WBX pressureplate, with minor reaming.
I heard that the custom disc has been made with 412 solid center and the 228mm Audi disc parts were bolt on to the original 412 center part holes. That´s amazing if that is true, but I´ll make more reserch about this.
http://www.youtube.com/watch?v=LQ8uukUGkXE
- Wally
- func412
I got more information today, very interesting indeed. Now the slipping clutch and poor flywheels are history
I´ll quote this information from www.fvwa.fi (Finnish vokswagen association) Forum, freely translatedinto English.
VW type 4 disc and Audi center
Audi center on top of type 4 disc
Type 4 center mounted into Audi disc, driven 10 000 km (Side 1)
Type 4 center mounted into Audi disc, driven 10 000 km (Side 2)
Here´s some pictures that Jouko sent me today:Jouko Salo wrote: Project went this way:
1. I bought Audi clucth disc, "Luk" Brand. It the package I found numbers 018-323041110 and 018-HB6463. In the center of that disc was numbers 018-323 0411 11.
2. The Rivets of both discs were grinded away carefully not harming the parts which were going to be reused. Both discs rivet spacing were exactly the same.
3. You need 16 pieces of 5 mm steelrivets to put a 412 center into Audi disc. I made a substantial base to bench wise from steel, where I grinded a small pit for rivet. The rivet was assembled with a help with my friend by heating up the rivet red-hot on top of that base, put the parts together and finally hit that rivet in place with proper arbor and hammer. After that I grinded the extra material away from the side rivet was hit by the hammer, only what was needed.
4. The disc needed no balancing, when I took it to machinery.
- Wally
