Building my first oxyboxer
Torch
Post by Torch »
Hello,
I'm in process of building my first engine using wasserboxer case. I'll be using my good old 84mm bugpack crank with 5.5" rods. For heads I have chosen MS230/4 heads from JPMotorsport, Sweden. Sweet looking heads! FK89 cam and Remmele 58g lifters with bronze bushings. I assume wbx case has same lifter bore than t4? I have also ordered 101.6mm JE pistons with 1.1" compression height.
What kind of head studs should I use? What about cylinders, where to find them? I've seen some AA cylinders on thesamba.com, are they any good? Any comments, what should be taken into consideration? I'm looking for reliable 250ish hp with lot of usable torque. Any comments would be appreciated!
