I know there is clearance issues with the cam when you get to a certain stroke, but what is the maximum?
Is it possible to use a 84mm stroke in a 1.9 case?
Gene Berg made a bunch of 86-90 stroke WBX cranks in the 80s. I'm sure they are all sold by now. If Jeff Denham can get a 92 stroke in a non dropped cam case, why can't it be done in a WBX?
I have just recently fitted a 86 mm DPR crank into a late 1,9L case and surprisingly little cleance work was needed I have not looked at the crank to cam cleance issure yet.
Guys lets make it clear are we building a water cooled engine or a aircooled engine? With a air cooled engine (using WBX block) yes you can do 90mm crank it will fit, But how much hassle for what little gain? As far as a watercooled its a bit differant story as you have to keep everything in the confinds of the stock cylinders & waterjackets. Unless you make special cylinders that are longer, Or pistons with differant comp. heights or both, weld the jackets of the block. Use shorter rods? Air cooled long stroke engines up to 90 mm are piece of cake compaired to a water cooled long stroke. Rolf is it a water cooled engine or a air cooled?? I have clearanced the 1.9 for a 88mm stroke w chevy style rods & 90mm could be done. Even better use the 2.1 block it has a higher roof again the cam must be clearanced (notched) not turned on a lathe. Thanks Rocky
Are u going to put it in a watercooled engine? Its the same as a 69mm bug crank so I would guess with the correct welding it could be made in to a 86mm if you spend the $$$$.
What tranny are you going to use? If you are going with a 901 or 915 then I would recommend sticking with the 228mm 914 flywheel. But if you are staying with a VW tranny then just get a T1 crank.
Personally I like DMS, but I have never heard bad things about either company.
If you want just give a shout on my cell and we can kick the can about it
