I say it 1972/3 Variant because although it was registered in 1972 it appears that some, if not all the parts are the later version. I have discovered this one by trying to find some replacement front disc for it. The front left one is badly scored from what appears to have been a siezed caliper (found in the box of spares in the car) at some point in its past. The disc that I need to find (I have a supplier looking for them for me) have a 60mm offset and 14mm pads instead of the the earlier 10mm pads with the 50mm offset disc.
Anyway on with the snag list though as I am top of the brakes, hopefully.
Firstly is the rough running at low revs. In a queue of traffic the car seems to stutter its way forward a quick increase in revs sorts it, but it is not a good idea to prolong it. It has been mentioned this might me down to the timing being too far advanced so shall have to dig my timing light out of the back of my shed and check this. I've already checked the points and plugs etc and they all appear to be in good order. However some of the airlines are a bit perished at the ends so is it possible it could be an air leak?
Secondly, there has been a worrying scraping/grinding kind of noise coming from the front left corner when negotiating speed bumps develope over the last week or so. Cursory examinations seem to point to the anti roll bar bushes being knackered as it is possible to move the anti roll bar backwards and forwards by hand and produce a quieter version of the noise. Fingers crossed that is this one sorted.
Thirdly, the gear selection is bit of an art as there is a lot of play in the gear stick so you need to feel and line it up as you select gears, if this is the same as the beetles I suspect it is down to a worn selector bush which should be straight forward to replace, but I can live with it as it is if needed.
Finally the one that has me really stumped (and cold) at the moment is the good ol' Eberspacher not working properly.
When I first got the car it would not work at all so I checked to see if it was all there and as far as I can see it is complete. I have replaced the fuel line (skinning my knuckles in the process) and checked the fuses and the safety cut out on the relay under the back seat. Checked and cleaned the spark/glow plug and then tried it out.
It worked
Great, I thought it was fixed...alas not
I can get the thing to run when the car is not running and cold but as soon as I start the car it will not run. Likewise if the car is warm and not running it will not run. It blows one of the 8 amp fuses and I am now at a loss to understand why. Anyone have an idea where to check first, could it be a defective connection somewhere or a duff sensor or something else equally obscure? This one has me beat at the moment.
Sorry for a long first post asking for help but I thought it might be easier than lots of little ones
