Everything thing was fine until 2 weeks ago.
One morning I started the engine and there was no oil pressure:eek:
I quickly switch off, checked the engine oil level etc, got back in car, started it and everything was fine.
I have fitted a vdo gauge and sender using a small brake pipe as an adapter.
This kept happening but not always.
Then yesterday morning it started with high oil pressure (4 bar not the usual 3 bar) and when warm returned to normal. About 1 mile from work it suddenly dropped from 2 bar to 1 bar. I dropped a gear expecting it to increase but it stuck at 1 bar.
When I got to work and stopped the car I again checked the oil level, restarted the car and there was no oil pressure:mad:
I came back 1 hour later, started the car and it was fine again.
Today I have changed the oil and filter and confirmed there are no metal bits or water/fuel in it. I also removed and checked the oil relief valve for dirt or being the wrong way round but it was fine.
To be sure I removed the oil pressure sender pipe in case the vdo sender was lying or air locked, kept turning the engine over and no oil came out
I removed the oil pump cover to see if there was any oil.
Oil did start to ooze out but I would have expected to see it more full.
I checked the pump and although there are marks on the cover where the oil gears touch it looks fine.
I am completely stumped by these weird events and have no idea what to do next?
Judging by the lack of oil in the pump all I can think off is:
1. The pump is too worn and unable to suck.
2. The oilway to the pump is blocked.
3. The pickup tube filter is blocked.
4. The pickup tube is not sealing properly and sucking in air.
Before I start stripping the engine down again can anyone advise?
Many thanks,
Iain.
