Hi,
I'm looking for some steel case savers/inserts for a oxyboxer project. I would like to use 10 mm head studs and need some thin wall thread inserts to fit the M12x1,5 mm thread in the case and have M10x1,5 mm for the head studs. Any idea where to get them?? Or should I just buy normal type 1 case savers and use 8 mm head studs?? The engine is a 86x102 mm monster with JP Motorsport heads FK89/98 cam etc
/Rolf
8mm head studs or special case savers
carsten bb
