Holes in rear wheel well to get to dual-carbs. (need idea's)
green1965bug
Post by green1965bug »
How are yall, it's been a couple of years sense I've gotten on hear. I still have my 65 Bug and now I have a 1915cc engine in it with dual 44mm Webbers. Im "thinking" about cutting some holes on the sides of my wheel wells to get to plugs and idle screws. Im not real excited about doing this because my 65 bug has never been hit or really cut on and she's in great shape. I would love some ideas, suggestions and some pic's would be great. Im not excited about doing this but if I can make it look good and clean, Im probably gonna do it. It would make life so much easier. Thanks for your time. Danny............
Eaallred
Post by Eaallred »
Is it for access to the idle jets, or for the manifold nuts?
On my old street car I made a very short flat blade screwdriver (about 3/4" long total) so I could make idle jet changes (or blow them out when they plugged up) easier. I've seen really short flat blade screwdrivers at Harbor Frieght for 99 cents each that look like they would work. For the manifolds, a swivel-socket and a long extension is your friend, especially if you use the small nuts avaliable at Aircooled.Net (3/8" head with 8M threads, VERY nice!).
These are your options if you don't want to cut the wheel wells out. Otherwise, a hole saw makes about the best cut, just make sure you cut it in the right location!
Eric Allred
1963 "Street Legal" Drag Bug
MegaSquirt 3 Crank Fire EFI
mightymanx
Post by mightymanx »
I am pretty sure it was glenn that did the hole saw trick for his engine bay it was very discrete and the pictures are here on STF some where.
green1965bug
Yeah, Im just thinking holes only for being able to change the idle jets and maybe holes to change the spark plugs. Thanks for the idea's and it would be nice to see those pic's of Glenn's. Maybe he'll see this and point be to his pic's, thanks the the ideas! Danny...........
FITNESSFORYOUTOO
Post by FITNESSFORYOUTOO »
I did a couple of street cars like this. I made aluminum panels to replace the whole section next to the carbs. I cut it all out but one inch all the way around the triangle. I fastened the new bead rolled panels with dzus fasteners inside the fender well.
This makes it look neat and changing spark plugs and jets is a snap.
Hotrodvw
Post by Hotrodvw »
"Weber Windows" 8)
Eric
green1965bug
Alright cool, now that I have some idea's Im off to Low's. Thanks! Danny...........
Dave Cormack
Post by Dave Cormack »
One of the slickest set of "Weber Windows" and "Dellorto Doors" I ever saw was back east at a car show... the guy had used the gas flap from a '68 and later Bug, and sectioned them into the rear wheel area. Spring loaded, stayed shut, and was a VW piece to boot...I took photos of them, but I'll be darned if I can find them now... I guess along those lines, you could use the square doors from an early Type 2, as well, and have them latch into place with the Bus "Church Key"....
Glenn
Post by Glenn »
I just cut 1.5" holes so I can ccess #1 and #3 plugs and the forward intake studs.
Tom in PA
Post by Tom in PA »
Just proceed with caution. I did this on my brother-in-law's bug and managed to drill through some wires running between the body panels inside the wheel well. Fortunately of all the wires, I just got one for the tail light. It took some minor surgery and some major patience to get things spliced back together. I never knew there were wires running through there :shock:
Tom in PA
Arnolds64
Done it.
Post by Arnolds64 »
Works great. Mine are a little high. Try to get a good angle cut with a large drill bit. Just get some 3/4" ply wood and slide it between teh carb and the side wall for protection. Once you have your hole then all you have to do is slip your long 3/8" drive extension in the hole. You then reach down to the inside next to the shroud with your socket. I use a swivel head since the hole is a little off. I just got some rubber corks and push them in the holes when done. They work and do not come out.
Yeah pull the sound deadening tar boards out of the sides first so you can see the wires as mentioned and tape with them out of the way. Then drill.
vw folks
Post by vw folks »
Years ago I saw a guy that had put windows in his car too. He used the access panel from the pan for the shift coupler. ( you could also use the access plates from the trunk area )
The thing I liked was the use of original VW metal.
Cometat4
Post by Cometat4 »
CB Performance sells a kit to turn the carbs around so the jets face the inside. Or you can get a machine shop to make adapters
CB Performance's kit is called space saver manifolds
Good Luck
RObert
Eaallred
Post by Eaallred »
Cometat4 wrote:CB Performance sells a kit to turn the carbs around so the jets face the inside. Or you can get a machine shop to make adapters
Good Luck
RObert
Downside to these manifolds is they make the throttle plate "tip in" toward the outside of the manifold rather than in toward the head. Not a real big issue, but every bit helps!
Eric Allred
dbcflash
Post by dbcflash »
Perhaps the covers you find in the spare tire well for the steering box would do well. It is a VW part and simple to install.
