I need some input on my 2789 Oxy project. The main things I need help with, is deciding how big the valves with matched ports will need to be in the heads I allready have, or suggestions for other type of heads for this engine. Both the 48X40 CE`s and the 50X40 910`s were found too big and then way too big for my intentions by "the pro`s".
The rest of the list has more or less been decided and purchased, but inputs on the rest is also of great interest.
This engine will stay NA, and will be used in my fiberglass buggy, for track and some strip, and will probably not see any street at all.
The thoughts with the engine is to have a ( stupid ) big engine, that will not be on its peak when it comes to power output, for a longer lasting engine life.
The more bottom-end power there is, the better it is also, since the local track is "short", with hard turns. I have been told by several engine builders that the cam I have chosen will work fine, especially since the engine is this big. Smaller heads, carbs and exhaust then a typical race setup will make more of the wanted power range, I think.
Tell me what you guys think about this set up:
2789 OXYBOXER FOR MY BUGGY
CASE: WBX 2,1 DJ, Modified for aircooling, cam lubing mod, maby shuffle pinning also
HEAD STUDS: 8mm molys with std. T1 case savers, or 10mm molys with time-serts, both for a ”bolt on” combo
HEADS: Sauer Aircooled “T1 looking” twin spark heads, 40X35 with wbx stud spacing ( needs work! How big valves ?)
CRANK: T1 Type, Scat Pro Comp, Super Lite, Knife Edge, T4 Mains, Porsche Journals, Wedgemated
FLYWHEEL: 200mm Wedgemated
CLUTCH: Not sure, but probably Kennedy Stage 2/3 and a good disc ( which one ? )
CYLINDERS: 101,6mm with cooling fins
PISTONS: Speed Pro ( Chevy type ) Coated Hypereutectic Noched Flat Tops. Measure 35mm from the bolt centre and up
RODS: Porsche 912, slightly clearenced, weight matched
CAM: Engle FK-89
ROCKERS: 1,4:1 With needle bearings
LIFTERS: T1 type Scat Lube-a-lobes in Rocky`s bushings
PUSH RODS: Moly(?) ”cut to lenght” type. ( Bugpacks? )
STATIC COMP. ESTIMATED: About 10-12:1 or higher
INLETS: Modified Type 3, short ones ( CB ? )
CARBS: HPMX 44 with Pipercross foam filters and homemade linkage ( yes, they are a bit small )
FUEL: 98 Octane pump gas / E-85 or Methanol , did`nt really decide that yet, but Methanol would be best I think
TRANNY: 4 Speed 091/1 ( sideshift, not midshift ) modified to frontshift, and maby with a limited slip diff
SHIFTER: Gene Berg
EXHAUST: Merged Collector ( cant remember how big it is. 1,3/4” / 1,1/2” ?? with a ”full flow” carbon silencer from a motorcycle
IGNITION: WBX or the 009 copy with the ignitor
