Could you tell us the brand on the bearing? There were a few small quality issues years back. Generally I have found only three brands that make this bearing. There was SKF...and those are really hard to find at all. There was FAG...superb quality (I think they are Fafnir now) and there was Timkin.
Timkin is known to be generally very good quality...but I did fond some hardening issues with some off and on.
If the bearing is pristine...it may have been a race hardening issue.
But...I have found that the bearing rollers can "look" pristine...but you then find that the cage is a little loose. The cage is generally softer material.
Most of the Timkin bearings of this part # were made at Timkins factory in France.
At one point in time I was finding Races...being sold separate from the bearings under the brand name CR....which is really just a conglomerate bearing dealer. You would open the box and find timkin or FAG inside.
I would not risk that the bearing is pristine...because you really cannot see the condition of the inner race.
You can...on known excellent bearings just buy a new outer race. But...ou can't use a good used race with any other bearing except that which it was brokin in with.
For a couple years when I found race isues like you have...I went to the junkyards and rescued pristine German bearings and races....cleaned them and I have them stored wired together in transmission fluid
. They are moticably smoother than some of the new bearings.
I find better life by packing better than the books say you should.
The other issue I have found also...is that previous owners get in a hurry and do not install the inner race 100% straight.
Last issue. If you remove the bearing cover clamping the race from the outer bearing....the one on the brake side...you sometimes find a tolerance issue...meaning the race does not fit tight in the bore. I am not sure oif this is an issue with te hearing bore getting out of tolerance or the bearing races being out of tolerance. Ray
