Got a TMI carpet kit for out Hybrid vert. 71 pan and 61 Body. the foot area kit fits from firewall back to rails and side to side. wear panels are in right spot, but the cut out and grommet for the shifter is Way froward...about 6". Were there any VW's with normal pan dimensions, but had the shifter mounting froward more? Or is it a total fluke on TMI's part? All other parts of the kit fit perfect!
Jon
Carpet kit shifter cutout in wrong spot?
- sinistervw
Memory tells me the early/late shifters were in different places... IIRC the later ones were further back, and the shifter was straighter.
- sinistervw
Did a little Googling, the came up with an example:sinistervw wrote:any chance you know where the year change was? we ordered the kit for the 70 pan part...so it should of been right!
SCAT drag-fast straight shifter is for 68-79 models, the angled back one is for <67
I don't recall the offset, but it could explain the issue if they sent you an early carpet kit.
- sinistervw
Chris V
