WHere do you connect your Stereo wires????
vwbill
Post by vwbill »
Hey where do you install the Red Battery Hot always , Yellow Ignition On Power, White Dimmer, Black Ground, ? bill
Doing stereo and leaving the old head unit and added one under the vent controls changed the doors speakers and added tweeters at the side vent and the dash corner with wire running that edge after unscrewing the dash there. Added a re cargo board that started at carpet and ended with patterned light brown recliner grids fabric with two Sony 4way 4x6 180watts it was the second attempt after a hammer toke out the edge of board one hitting staples!
albert
stereo wire
Post by albert »
,,BILLS i d,t know what kind of stereo you have but , for me i have old audi car radio ,and the connection are the same for all the radio,, you can have ,,one red wire with a fuse soket,( 3 amp. ) , this red wire go on the car fuse block on the fuse 9,,( for the 411-412 ) and if you have the ,,orange wire ,( maybee light red too ) , ( he can have a fuse soket with 1.5 amp. ) you can put on the fuse 9 too ( if you want to see the radio light ) the orange is for the mémory in the radio , and if you want the radio wend the motor is off,( if not you connect the orange wire on the fuse 7 ,,( gas pump ) ,( that geeve me information if my pump run ) ,,,= ( no radio, no gas pump ) and the ,,yellow,,with round plug-in ,,is for électrick antenne ( what i have on my 412 ) and the rest is for your speakers ,, many radio geeve you the black wire for the ground ,,on the car frame ,,on the ligther ground ,,if you want ,, albert
wildthings
Post by wildthings »
Check your operating instructions carefully to see if there is a way to turn unit off if both the yellow and red wires have power to them all the time. On my Sony I have to push and hold the off button for 5 seconds to turn the unit off. Other brands have different but often similar procedures.
vwbill
Post by vwbill »
Thanks guys for the replys! Albert I guess running at least one wire of my new radio head unit to the actual radio fuse of the fuse box would be better but I ran it to the cigarette lighter Hot and Ground both there; That makes me wonder since I blew the cigarette lighter fuse remounting the wires once and I thought it was fuse 10 but "9" is labeled Cigarette,heater(switch current) and I don't have the front blower working? Have to check on that one! I put the White to dimmer, Ign. switch on Hot wire to fuse 10, Wipers fuse spot. Thanks Bil
P.s. I didn't think about doing VW hot radio style with a "Off" function of the Radio Head Unit!!!
albert
stereo wire
Post by albert »
that can be a good place too ,,albert
vwbill
Thanks for the pic!
Post by vwbill »
Thanks Albert! The pics show me that the fan is big and set way back in the body dash top fire wall!! Looks like I would have to remove the radio again to get that disassembled which means That I should have just did that first!
I hope it is just wiring missing or connected wrong not a bad fan! Wonder if it has a relay or not or just out of fan to switch and power to switch?....
Here is one of the dash look...
http://groups.msn.com/VW412/shoebox.msn ... hotoID=111
albert
stéréo wire
Post by albert »
,,bill,, you have 3 wire on the motor ,,, one low spead one hi spead and the ground,, and on the slider swith you have 2 cupper contact ,, plus one ground,, if you mix the 2 color wire from the motor that is not very important ,, in the normal thing you start bi the low spead and hi spead afther ,, but if this 2 wire are mix , you start bi the hy spead ,, just reeverse this 2 wires,, albert
