Weber 40 idf float level
dc10driver
Post by dc10driver »
Hello gang I am in the process of finishing my dual carburator set up. I was advised to open them up and adjust the float level on my brand new carbies. Is there a specific number that is recommended? What is the easiest way to accomplish it?
Diego
fortyeye
Re: Weber 40 idf float level
Post by fortyeye »
dc10driver wrote:Hello gang I am in the process of finishing my dual carburator set up. I was advised to open them up and adjust the float level on my brand new carbies. Is there a specific number that is recommended? What is the easiest way to accomplish it?
Diego
AKA clearsurf
udidwht
Post by udidwht »
Old thread I know but the float setting only shows the drop measurement.
The float height should be in the range of 10 - 11mm with the gasket in place and ball NOT depressed. The drop is less critical and is 28-32mm (gasket in place ball NOT depressed). Fuel pressure no more than 3.5psi max (otherwise it will push the needle off the seat).
Kafer_Mike
Post by Kafer_Mike »
Blackline Racing has a good video on the process -- https://www.youtube.com/watch?v=54uPwTZ3DJwHow to set Carb Float on IDF Weber
"Build 'em fast...or let 'em sit"
