924 / 944 / Thing (2) Stub Axles, (4) Type 4 CVs, (2) Drive Axles, (4) Boots, (12) Mounting plates, (24) Bolts. This setup is great with a stock Beetle IRS Transmission and stock Trailing Arms. Type 4 CV joints (944 / 924 / Thing) 100mm CV joints gives 22 degrees of axle travel. These axles are the right length 16 1/8 inches. See blindchickenracing.com for details. Splines and Threads are in xlnt cond. $225.00 plus shipping.
"Let me say it as simply as I can: transparency and the rule of law will be the touchstones
of this presidency,".. Barack Obama January 21, 2009, 30 minutes before he signed the law
sealing all his personal information....
Don: The set pictured above has been sold, I did pick up a set from a 944 last weekend - I haven't cleaned them yet. It has 2- Stub axles, 4 - Type 4 CV joints, 2 - 16 1/8 Drive Axles and the mounting hardware(Bolts and Plates) $220 shipped, $200 without the Drive axles (if your going bigger than the Standard Beetle trailing arms, these axles would be to short) No boots - they were cracking, but not split
Joe
ntsqd: The second set is gone, but I have a 3rd set from a 924 I picked up a couple of weeks ago. They are complete - (2) Stub Axles, (4) Type 4 CVs, (2) Drive Axles, (4) Boots, (12) Mounting plates, (24) Bolts. $225 plus shipping of $20.00. Total of $245.00
I picked up another 924 setup. (2) Stub Axles, (4) Type 4 CVs, (2) Drive Axles, (4) Boots, (12) Mounting plates, (24) Bolts. Splines and Threads are in xlnt cond. $225.00 plus shipping. 3/14/09
