brake bleading
albert
brake bleading
hy,, i have see one thing wend we blead the 412 brake,, if we have change the ,,m,c, and if we have remoove the brake pedal , wend we do the instalation if the brake pedal d,t go on the top we d,t can bleed the brake to the perfection,, for that make sure if the pedal spring can push the pedal on the maximum,, if not ,turn the pedal spring for to geeve the maximum on the pedal,on the top,, if the piston in the m,c,, stain in the midle of the course ,you bleed only the 1/2 of the systhem,,and your brake stay soft all the time ,, albert
