Paul H wrote:Hello
Just toying with the idea of producing some new affordable heads for the type 4 engine.
Yeah Yeah heard it all before I know but this is a serious idea.
Just a few questions for the type 4 people.
Do we make the exhaust ports like a type 1 ( I say yes)
Do we alter the pushrod tube entry point more like a type 1 ?
Do we alter the rocker mounting system to cater for more type 1ish set up?
The heads will be die cast of similar alloy to the original VW and as the cad work and tooling will be close on $30k we need to get it right and to cater to the masses rather than radical modified stuff.
Fire away
If you are really serieus, I will give you my thoughts, but I am not sure they agree with your ideas, which seem to be already somewhat made up...(?)
Type 4 heads with type 1 style exhaust ports already exist for many years. Hell, there are even two kinds made and I don't think you will improve much on those...
I know thay are much more expensive, but $ 800,-- for a set of new type head castings is hardly to be taken seriously if they would be of any quality at all. With quality I mean not throwing away one of the main benefts of the type 4 head casting: cooling ability!
A set of type 4 heads that would look and cool like a solid Eliminator casting or something like that would NOT be an asset to the type 4 community imho.
A cross-flow head style that a type 4 head really is, has been made for more than one reason by VW. One of them is torque producing.
The rigid idea that a type 4 exhaust port flows less than a type 1 head is really, really been outdated!
I and some others have 'proved' this by using a stock 914 head casting and with NO WELDING done produced 220 hp in N/A form!! The exhaust ports were also only touched very limitly.
Actually most of the things you opt to change out are benefits to the type 4 over the type 1. The fixation of the rockers for instance: the type 4's 4 studs are WAY better than the 2 studs the type 1 head uses!!
The only thing you mention that would help abigger exhaust on a type 4 somewhat is a slight moving of the pushrods so that a larger exhaust header could fit more easily.
Not mentioned, but an item of a type 4 head that could be improved upon is the stiffness of the head itself. Due to the uneven head stud location, warping is always close by with a type 4 head, so more strength in the head at the right location AND a better aluminium sort would do some real good for tuning with large bores (103's).
The twin plug remarks are spot-on as well of course
You really are prepared to spend $ 30K on a start-up?
What parties are behind this idea then? So I believe this is serieus or just day-dreaming.
