how many hp. before wedge made?..
bang
Post by bang »
hey.
got a spare 86mm wbx crank and want to use it for an 2387 turbo oxy projekt. how many hp do you guys think it can handle with the org 5 boltholes and 5 pins before i have to wedge made it?
is there another flywheel setup there is better or? porsche use 6 bolts for flywheel and what do they do when they pull many horses out? .
the crank has been used in my 2779 drag engine but i lost the flywheel, so i got a new dpr crank with wedge made flywheel for that.
thanks
big bang racing
denmark
fastback
Post by fastback »
these flywheelbolts also would help alot.
http://www.ahnendorp.com/wabo4.html
DORIGTT
Post by DORIGTT »
How do you just 'happen' to have a SPARE 86mm crank? What kind of trees do you have growing in your garden?
bang
Post by bang »
i allredy run with b.a.s bolts and will use it for fast street turbo engine. 350-400 hp in a oval. no dragrace
it is an demello welded full curcile
bang
Post by bang »
Stripped66
Post by Stripped66 »
Just wedgemate it; don't screw around.
bang
Post by bang »
anyone know where it can be done in europe?
Stripped66
bang wrote:anyone know where it can be done in europe?
I would think any number of the Type 4 engine builders would be able to point you in the right direction.
TomiSe
Post by TomiSe »
I suggest flanged T1 crank with all T4 journals. I'm running wedgemated T1 crank in my oxy, but will change it to flange crank, it just feels much stronger.
Wally
Post by Wally »
The 5 BAS bolts with the larger toque setting can hold enormous power. Another 5 dowels added only reduce the plain of the crank that has to transmit the force. I decided not to go that route.
I had the BAS bolts already transmit 345 Nm with slicks and did quite a lot of runs with them in my 1000 kg bug (including me).
