Updated my daily driver a bit...
2stroke
Post by 2stroke »
8)
big boy fuel system on top, old stuff on bottom
jcl springplate retainers, saw springplates, RLR adj shocks
trans has all billet weddle parts/gears, alum spool, saw axles, berg rubber midmount, rhino trans mounts, eyeball kafer brace
new stance from 3" beam, drop spindles, ghia disks, M&H front runners and M&H 235/60 dot slicks.
and the new 2442 powerplant Smile
water pump, radiator (THATS RIGHT)
watercooled CB CNC comp eliminator heads 48x38 valves
water reservoir (mounted in package tray)
parts to fab stainless steel header
custom reverse bolt pattern plates to mount 48 dellortos.
1 5/8" stainless steel heater boxes (using gutted stock units)
finished header, autocraft stage and a half pump to scavange oil from low mounted turbo
alum intake fab
Decklid closes completely, runs cool, and hauls ass!! :D
Coyote
Post by Coyote »
A bit ! ? :shock: :D
no problem with the 911 fan sucking through the header?
turbobaja
Post by turbobaja »
Nice looking work there 2stroke!
Hell of a 'sleeper'. Looks like the deck would close easily.
Have you had a chance to put it on a dyno yet???
I'm a little concerned about the lifespan of your fan belt. Looks like that header (whick looks totally badazz, by the way) might get that belt a little toasty. I could be looking from the wrong angle, though.
Nice ride man :twisted:
2stroke
Post by 2stroke »
Coyote wrote:A bit ! ? :shock: :D
nope, even with the decklid closed, it runs cool, im sure with the bottom propped it would only get cooler.
turbobaja wrote:Nice looking work there 2stroke!
Nice ride man Twisted Evil
luckily belts are cheap, no dyno time yet, not sure I will, I'm going to convert the clutch to a dual disk setup then ill get some timeslips on it.
Kenny2428
Post by Kenny2428 »
Nice job man...im envious!
Mabbo
Post by Mabbo »
that is cool as fook
8)
Ghia Nut
Post by Ghia Nut »
dayyym
that is hot
and your car is awesome
doesn't scream trailer queen
thats a very similar car combo Im aiming for
Wally
Post by Wally »
Such a nice and uniquely design engine! Placement of the turbo is very cleverly done. Me like! Very nice indeed.
But why still running carbs?? The modulator rings surely cost you a lot of flow and hence power (not to mention fuel..)
Next update EFI?
turbobaja
Post by turbobaja »
Are you still using the boost referenced float bowls? Sounds like it was working pretty good before with high boost levels.
Are you monitoring head temp?
ToRy 70
Post by ToRy 70 »
Sh*t's the tits!
What's the story with the v-band clamp holding on 6 inches of pipe? Do you have a muffler setup to swap on?
2stroke
Post by 2stroke »
Wally wrote:Such a nice and uniquely design engine! Placement of the turbo is very cleverly done. Me like! Very nice indeed.
Next update EFI?
Using carbs because i have them, No mod rings, look at the picture of my carbs that turbobaja posted, from that an fitting a 3/8" hardline goes into my boost stream to catch a good flow of pressurized air.
If/when I go efi, I will ditch the dual setup and do a single aftermarket 5.0 throttle body.
I am monitoring head temp via a water temp gauge (something you dont see often in a bug)
yes the Vband setup is so i can change from straight pipe to a muffler setup.
64bug
Post by 64bug »
Insane! nice work man!
Billyisgr8
Post by Billyisgr8 »
Right on Andy...so will we see a tripple bumper next time at the races..haha?
Nice placement of everything.
Kevin
MarioVelotta
Post by MarioVelotta »
Nice work. It's cool to see something so unique.. How hot does your water jacket run?
The Dub Shop
Mario@thedubshop.net
1600 ITB NA - 18sec
Facebook-Tech-Store
2stroke
Post by 2stroke »
MarioVelotta wrote:Nice work. It's cool to see something so unique.. How hot does your water jacket run?
250
