tossed the alt belt...
- vwfye
... went to put it back on and found that the pivot bolt for the alternator is GONE! don't know if it broke or backed out. anyone know what size/pitch it is and if it can be put in with the engine in the car? haven't been under there yet to see what i need to do, but i'm headed there saturday.
Notchback mid-engine speedster
Little Giant Killer 3
- Lars S
Look at this page, item no13 I believe, Screw M8 X 71mm (with special head?)
http://www.pelicanparts.com/PartsLookup ... Frame3.htm
/Lars S
/Lars S
-914/4 -72 daily driver
-Husqvarna 120cc rat bike -48
-Husqvarna 120cc -52
-BMW 600 Road Scrambler -69
-Suzuki T500 Cobra -69
-VW411LE 2-door sedan -70
-Porsche 914/4 -72
-VW412LE 4-door sedan -73
-Suzuki K50 -77
-Porsche 914/4 -72
-Suzuki K50 -77
- Lars S
I would believe so, this thread should tell what is possible or not for an alternator in a Variant:
http://www.shoptalkforums.com/viewtopic ... 51&start=0
Lars S
Lars S
-Porsche 914/4 -72
-Suzuki K50 -77
-Porsche 914/4 -72
-Suzuki K50 -77
- vwfye
- vwfye
Re: tossed the alt belt...
after what feels like forever, the alternator mount is fixed! now, i just need to replace the very stretched belt and bleed the brakes! drove it 3 miles and had to mash the pedal to the floor for any braking at all. but, i drove it! put some blue stock wheels with trim rings on it and i think i like it.
yes,,vwfye,, we can put ,,or change the alt. witch the motor in place,, 6 hrs,, send me pm ,,for all the pict,,25 pict, not nécessary to remoove the heather box,,albert
- vwfye
no, it's already done, i just have to get a smaller belt now. it's all good!
oh,,, ok the best ,,remoove the right side tail light ,,tail light housing ,,and by the hole you can go inside for to pass the belt over the oil tube,couple hrs,job,,,page 148 in the haynes book,,
oh,, one more thing,, the most hard is to slide the belt bitween the rubber boots and the fan case,, but just loose the clip bolt on the fan boots ,,(on the fan side ) ( d,t remoove the clip just loose the bolt ) and push the fan boots for to slide the belt over the fan ,( make sure wend you put back the fan rubber boot is in her good place beefore to tight the bolt on the clip ) ,sometime ,, i remoove the fan cover onder the car ,, only 3 bolt for to remoove that,,( 3 flat head screws in the motor section,,) this information is for the wagon,, i have make this job 3-4 times,, and that take appx. 2 hrs,, and appx. 6 hrs for to change the alternator witch the motor in the place,, and i d,t remoove the heather box on the right side like haynes said in her mec. book,,i have 20-25 pict. for this job,, albert
- MGVWfan
Whew! Glad you solved the problem.
That rear nut on the alt pivot is a pain to get at, I usually end up using one of those ratchet-end box-end wrenches to loosen it enough to get it out of there.
- vwfye
it's all together, insured and was driven today! tomorrow it does the 48 mile round trip for work
oh... 12,000 miles on the car since the springs were cut to level it out. still ridin' smooth, straight and comfortable.
- vwfye
running well less the MPG and i have this odd mystery miss that happens on occasion. i had it before the car got parked, but the 1st 2 tanks of gas after bringing it back to life there was no miss. now, tank 3 has it back.
