There is a small fluid leak on the master cylinder, which is the dual circuit for '69 bus, no servo---coming from the rear outlet with the wires for
the brake/warning lights. I tightened the fitting, but it is still leaking.
Any thoughts? Unscrew the fitting, perhaps use some teflon tape?
New Master Cylinders are running $150 or more--don't want to replace it
if not necessary.
Cheers....
