2000 Jetta front bumper, new center windshield bar:
New dash bar, "Petty" bar, .032" aluminum dash with beads rolled in - access for gauges, new steering column, splined quick disconnect steering wheel, Simpson cam-lock belts, 8-AN fuel line runs through a 3/4" EMT on the passenger floorboard, 1/2" EMT for future re-wiring of fuel pump(s), lap counter transponder, radiator fans, and wiper:
Oil pressure, water temp, oil temp:
13x8 Aero wheel with 2" backspace - hiding behind it a Type III rear drum:
1780cc, CNC ported head, some big cam, adjustable cam gear, header, Holley 350 CFM carburetor, MSD coil and stock Haltech distributor, nice new aluminum radiator w/dual fans:
6-fuse electrical marine panel...relays so the switches in the car don't actually handle the current - (S) solenoid, (F) fuel pump, (IC) ignition coil and another hiding back there for the rear window wiper:
Solid mounts:
Tapped 1/2" NPT for water temp sender...other holes filled with pipe plugs, JB weld and cam followers
Stock throttle cable - new mount on valvecover, heat shield on header - still need to get some exhaust wrap, oil pressure sender:
Well, that's about it...it's kept us busy and poor.
