won't turn over.
Piper
won't turn over.
So i decided to try to start my 83 westy today (1.9 water boxer) and she won't turn over, the battery is freshly charged, but she cranks like its dead. Put the battery back on the charger, and it says its good (not 100% but still in the green zone). I was having this problem in the fall before I took her off the road, and assumed it was the battery, but like I said, the charger seems to think the battery isn't the issue. I also tried the battery out of my Toyota Tercel, with the same results, and yet in my Toyota, she fores right up. Any ideas what may be causing this before I have her towed in for a look at the garage?
wildthings
Have a helper to turn the ignition switch for you and then read the voltage drop at every connection. Post to cable, one end of a cable to the other, cable to solenoid post, etc, including doing all your grounds.
Your local discount auto may have an induction ammeter that will show your actual current draw as well.
Piper
