1967 dual circuit master cylinder bore size?
Mood
Anybody know the bore size of a 1967 USA spec splitty dual circuit master cylinder? It probably is 7/8", but I want to be sure. Thanks in advance.
Mood
the verdict
The bore is 7/8". I needed the seal that prevents external leaks at the pushrod. I got a perfect replacement from an 80's Volvo ATE master cylinder. The doner m/c should be ATE and have "22" cast on the outside.
A buddy had the same seal rot away in his '68 camper whereas the rest of the seals were perfect and so was the bore.
