the combo will be a 82mm crank and 99mm cylinders.
The option i'm looking at is
1. keep the stock cyl length
the con's with this is that this need's a piston design that the 3. oil ring comes over the wrist pin. to get the correct compression height. with the rod's i'm gonna use.
the pro's is that the longblock stays original.
2. make the cylinders 3mm longer and have the option to run stockish style pistons.with this the 3. oil ring comes in the "normal" position
the con's is that i then need a 3mm spacer for the waterjacket seal. and modify the exhaust.(but i'm uilding a new wxhaust anyway..
any thought's
