New Brake Drums
- raykinsella
New Brake Drums
Does anybody here know if type 4s have their own brake drums, or do they share the same ones with other VWs? I need some new ones and don't see them listed anywhere.
- raykinsella
- raykinsella
Okay, I saw that the number under the windshield matches the number on a sticker on the inside of the driver's door, which also shows the month and year the car was built. The number was well beyond the 411...range of earlier models. So it's the same drum for my 411 and then my 412s? I see the drums listed for the type 3s online, so they should work. They look about right - four holes for lugs and two for the screws that hold the drum to the hub.
are your drums damaged/worn out? it'd be worth it to find real German replacements, Brazilian drums are known to be... inconsistent.
this post has a good overview of brake issues...
Well put. The brazilian drums are good...but there is a very important issue to find out with each one you buy. They are cast in one piece and then have the swept braking surface machiend into them. It has been pastexperience that some....as many as 2 in 5 that I have personally purchased...had the drum mounted in teh mill incorrectly when the braking surcace was machined...and it was then....eccentric to the shoes...meaning it acts like its warped.
They are good drums....but just flat out tell the person you buy them from that this has been a problem and you will be checking it and returning for a trade out...anything that shows eccentric braking surface. You don't even have to drive on them.
These cast drums are heavier.
The stock German part was a two piece drum. The material for the braking surface is different from that of teh flange plate. They are superb in accuracy. Also...almost impossibel to find. Ray
