small rectangular pieces of tin
69BeatL
Post by 69BeatL »
/Users/dummy/Desktop/IMG_0348.JPG
I'm reassembling the engine of a 69 Beetle after a valve job, and have two small rectangular pieces of tin with a tab at each corner. where do the go?
baja5
Post by baja5 »
Sounds like you have the lower air deflectors. they snap into the lower head studs above the pushrod tubes. make sure you put them back in.
baja5 wrote:Sounds like you have the lower air deflectors. they snap into the lower head studs above the pushrod tubes. make sure you put them back in.
...before the pushrod tubes/heads go on...
You have to post images to a web reachable/readable site, your ISP may provide some space, or use something like photobucket etc.
You can then link from there...
