i have a small rust spot just ahead of the rear fender in the rocker panel. what is the best way to approach this problem? i know it will be the size of a dollar when i start scratching at it.
new top is on k-man thanks much for the vidio.
small rust spot
- david58
Re: small rust spot
Use baking soda in your hand held sand blaster.maineshops wrote:i have a small rust spot just ahead of the rear fender in the rocker panel. what is the best way to approach this problem? i know it will be the size of a dollar when i start scratching at it.
- david58
Baking soda will strip paint, remove rust, and is great for working in small areas it won't damage glass or rubber. Since it is rusted thru make a patch panel and weld it in, after blasting.maineshops wrote:its rusted through. sorry for the confusion, and i don't want to mess with it until i hear some definitive answers about this kind of fix. i don't know too much about cars.
