The trunk space, needs some work:
Not the full extent of the Evilness that is Bondo: (The whole front end is getting replaced)
The Bondo Infestation is over 1/2" thick in some places: (Also will be replaced)
The Drivers Front:
Dad's (BAJA-IT) Good side:
My Car's Good side: (Literally, the only good side)
The Passenger Rear when I was finished removing the infestation:
The inside:
A little bit on the roof, but used correctly here:
It's a '72 Standard, and it will look similar to this when I'm done, the three white stripes probably wont be on the finished car: (Concept created by a friend)
