* 17 x 7.5 x 55 ET Porsche Cayenne wheels; 195-40 front (edit: mistake of 195-45 corrected); 205-50 rear
* 911M front calipers (48mm) with 944 vented rotors (20.4 x 282 mm)
* 20AE Golf rear calipers (38 mm) with 944 vented rotors (20.4 x 290 mm)
* Brake bias valve removed for 1.60:1 brake bias with stock 19mm 412 master cylinder (same as 911)
* Delrin bushings front and rear
* Adjustable front camber and caster
* Lowered front with BMW 318i springs and Koni adjustable struts
* Super Beetle strut bearings and strut brace
* Mazda front spring plate bearings
* Rebuilt steering box
* Modified NOS centerline and ball joints
* Re-sealed fuel tank
Notes:
* Fuel tank is full in before shot and empty in after shot.
* Not aligned yet - front subframe is shifted to right a bit.
Driving observations:
* Much firmer front end
* Steering response quicker and less force required
* Shimmy is gone
* Some squeaks and rubs to debug
* More brake bleeding needed
