Turn Signal Flasher
- MrGolf
Turn Signal Flasher
Where is the turn signal flasher located on my 76 Westy. Turned them on and it flashes like a machine gun..............Then quits................on and off.........tried 4 ways too and it does the same thing..........My guess is the flasher................all bulbs light. Ant ideas..........Thanks
busman78
Re: Turn Signal Flasher
Flasher is plugged into the bottom of the fuse panel, first relay on the left, plastic rectangular box if it is still the original . Could be the flasher, also could be a ground problem with the emergency flasher switch.
